W
walle62
Dear Friends
I must design for my company a solar cells (17 V nominal) to lead acid
gel battery (12V nominal, 14.6V charge final voltage) charger.
I want to use a pic single chip computer with A/D and D/A-converters
for regualting between solar cells and battery/load line with two
cool-mosfets (these are the same as a logic level mosfets). the unit
should also prevent against solar back current in the night,
overcharge, undercharge and load over current.
I also must implement a battery charge measurement (in Ah), i want to
do this with the pic (measuring the battery charge/discharge current
and integrating this current up/down respectively).
The surge load current is 20A or 40A, nominal load current is about 5A
or 10A.
Do you have ideas, critics, questions or suggestions? I'm glad about
every answer from you. I also would like to help somebody with similar
questions. For a very helpful idea or a good design we would pay, if
you want. Thank you very much!
Walter Nussbaum, dipl. Electronics Engineer ETH, Megasol Inc.,
Höhenring 17, 8052 Zürich
mail: [email protected]
phone: +41 43 268 90 32 mobile: +41 79 297 62 78
or 10A.
