Here is my idea of a solar car(obviously I am not going to build it because it would involve welding and high voltage, both of which are dangerous).
No hydrogen is needed here because it is completely powered via solar power.
When it is charging, the solar panel is connected to a cable that plugs into a socket on the top of the car. This sends electricity to the battery and charges it up. Once it has reached 100%, no more electricity gets into the battery so it doesn't overcharge.
The battery powers everything from the lights to the motors that actually move the car.
I want to focus on the battery, motors, and built in multimeter.
There are 2 motors here, 1 on the left and 1 on the right. They both have a hot wire which branches off of the wire that is connected to the negative terminal of the battery(a hot wire sends current to the component in question). They also both have a neutral wire(neutral wire sends current back to the battery) which connects to the wire that is on the positive terminal of the battery.
The multimeter is also connected by a hot wire to the negative terminal and a neutral wire to the positive terminal. This multimeter is used mainly to know when the battery is getting low so that a person can get to a solar charging station or back home, before the battery dies.
This battery gauge is used for the same purpose as the multimeter but doesn't show actual numbers or units.
Whether or not the battery needs recharged is dependent on the voltage but more important than that is the amperage. If the amps get too low, it doesn't matter what the voltage is, the battery needs recharged.
High amps but low voltage, recharge
High voltage but low amps, recharge
Low voltage and low amps, recharge
High voltage and high amps, doesn't need recharged
Now let's focus on the 2 motors. These determine the velocity of the car via voltage and voltage difference.
If the voltage difference is 0, the car will go straight. If there is a difference, the car will turn in the direction of higher voltage. So if the right motor has more voltage, the car will turn right and if the left motor has more voltage, the car will turn left.
The magnitude of the velocity, commonly called speed is determined by the voltage itself. The higher the voltage when the difference is 0, the faster it goes.
Is this idea of voltage determining speed and direction and thus velocity a good one?
Basically I have this circuit:
![Basic car circuit.png Basic car circuit.png](https://makerv2.webteractive.co/forums/data/attachments/33/33038-d2e828f1b61afab4c6a9d2c8b845368a.jpg)
LM means Left Motor and RM means Right Motor. With the neutral or black wires I am not trying to show crossover of current. Rather I am trying to show the merging of 2 currents into 1.
![Battery-Meter.jpg](/forums/proxy.php?image=http%3A%2F%2Fimthemechanic.com%2Fwp-content%2Fuploads%2F2011%2F11%2FBattery-Meter.jpg&hash=8c896e9a2d76d739f410a99eb0f3eb1c)
