And we're back...
Ok, picking up from where we left off....I wired up the refurbed system with all zones, sensors and only the working keypad - no sounder. These are the readings:
Typical zone outputs on the board have a 13.43 DC voltage when nothing is attached.
All zones that have a 1k resistor on them and a motion sensor attached register at 2.14-2.15 VDC. This is really odd because the manufacturer states that their devices work from 10-14 VDC and consume at standby 12.5mA at 12vdc and 100mA when alarmed. Does this make any sense? There are 6 of these devices.
The horn sounder section of the board has two outputs and they both read 10.32 VDC
with no load attached. The sounder is rated to operate between 6-13.8 v and draw 175mA.
This board was fixed by the manufacturer and supposedly tested before being shipped back.
I tried to get a reading on current being used, but couldn't?? I don't know if my meter isn't functioning or operator error
The scale goes all the way down to 20 microamps, so I am sure we are covered as far as range goes, but hmmm? I don't know what to make of that.
So far the board has tested out with all devices attached except the sounder and bad keypad and everything works well. Alarm triggers and dials out, remote sensors work, etc. I didn't have a chance to test the bad keyboard yet, but I am really nervous to test the sounder again
It might be possible that the devices are drawing collectively more than the 1A limit of the board.
Thanks!
