D from BC
Peak density at f gives core loss in mw/cm^3 to be picked off of the
mfr's core loss chart.
Temperature rise is 1 degree C per milliwatt per cm^2 surface area for
the shape of transformer chosen. (+/- 20%). Don't forget copper loss.
Ferrites with high resistivity, used almost without exception for
power conversion above 50KHz, also exhibit currie temperatures
significantly in excess of most commodity safety isolation systems.
If you see a currie temperature below 150degC, you've picked a signal
transformer or EMC (intentionally lossy) material.
RL
Neato...
1deg C
__~___
/1mW /
/__ __/ 1 cm^2
With 20% error..
Yup... Was looking at wrong mixes too.
I looked at Steward toroid cores (material 35 is available from
Digikey).
Curie temp 150
Resistivity 100 ohmcm
But I think the big clue was "Common Mode Material" is written at the
top of the datasheet
Not a choice material for power conversion
D from BC
British Columbia
Canada.
