I hope, we have seen enough in many examples that the Canadian tweezers LCR Pro1 have higher technical characteristics for all types of measurements compared to the Russian tweezers HB-14.
Two times smaller, much lighter, does not require constant calibration,has accurate, gold-plated tips.
It has a certificate confirming that the tweezers comply with all declared characteristics.
It has the output of information on the computer, which is very necessary in different dimensions.
It has a test voltage of 1 volt, which is very important for the correct measurement of ceramic capacitors.
Very simple and convenient menu that does not require extra time and does not distract from the measurement process.
Practically not replaceable when measuring in the circuit. Excellently cope with complex in-circuit measurements, where other tweezers are practically powerless.
There are no competitors in measuring the ESR of different types of capacitors, almost ideally measuring this parameter.
And the main feature of the tweezers is undoubtedly the micrometer. That allows you to search for the smallest short circuits in the board that are not available to other tweezers.
In practice, this is a radio electronic mini-laboratory.
Thanks to the Canadian engineers for the great and difficult work done.
I hope this project will develop further, because as you know, there is no limit to perfection.
PS When working with different RLC meters, refined and made with my own hands, I honestly was pleasantly surprised and amazed by the accurate measurement of small values of resistance, ESR and inductance.
Many of the unique results I achieved were easily repeated and confirmed.
What says about the truth of these results.
After all, these values were obtained in two different ways - simple analog and complex, using modern digital methods of calculation and processing.
So time and great efforts were not wasted.
This means that there is justice and it is worth fighting for it.
