W
Warren
I want to explore the effect of transmitting a guitar
signal through a small saturated magnetic core. But I
don't want to do this at high power levels, using
saturation of the output audio transformer (in tube
amps), as is usually done. I'm aware that some
Wah pedals do exhibit some distortion using a small
inductor, but I want to consider other approaches.
I want to do is to do this in the "small", at a
signal power level. Something like passing a signal
through a "core memory donut", or iron washer etc. The
idea is to find something more readily available than a
core memory ring.
My fear is also that a washer will not be effective
enough, may also require higher power levels than
desired.
The link below describes how to avoid saturation of
toroid cores:
http://lists.contesting.com/_topband/2004-01/msg00104.html
The example he cits suggests a max current around 2.4 Amps
for the example he cited. So this rules out toroids in my
mind, and probably even smaller ones.
One thought I had was to use some steel wire, bend it into
a very small ring and crazy glue the ends. Then try to
put some windings on it to turn it into a saturable signal
transformer. I'd have to guess at the windings in this
case since I'd have no clue on the magnetic properties of
such.
I'm looking for suggestions or better ideas. Or is it
simply better to purchase a small inductor? If so,
what inductor range is suitable for op-amp signal
levels?
Warren
core memory ring.
desired.
toroid cores:
such.
levels?
Warren
