Hello everybody!
I built a 1Hz oscillator using the time circuit from an old quartz wall clock. The oscillator is working wonderfully, I have a very nice, precise 1Hz oscillation, but the problem is, my output signal is not strong enough to drive my 74LS162 decade counter.
The output peak of my oscillator is about 1.5 volts.
I also built a 1hz oscillator using a 555IC, and that circuit's output is strong enough to drive the decade counter (peak is around 3.5 volts) but for reasons of which I am unaware, the decade counter increments on both positive AND negative half cycles. I compensated for this by using a 500 ohm pull-up resistor on the clock input, and the counter worked correctly thereafter.
So basically I am trying to achieve a similar Vout from my quartz oscillator as I am getting from the 555.
Major problem, I don't know the input inpedance of the decade counter (couldn't discern what it was from the datasheet). I wanted to build an impedance matching network, but I don't know what impedances I need to match!
Can I use just a very simple class a amp?
Many, many thanks for your help!
