Small P clips - not exactly electronic
nospam
I am designing a small PCB (about 15 x 60mm) which will have an M3 mounting
hole each end. I need to fasten a cable (probably 3-4mm diameter) to the
board and a small P clip under one of the mounting screws seems like a good
plan.
I have some p-clips in my junk box which are about the right size, about
14mm long and 6.5mm wide and would take a 5mm cable. The only marking on
them is "NXI".
I can't seem to find a source for anything this small. They all seem to be
9.5mm wide and even the ones taking a 3.2mm cable are about 18mm long.
Can anyone point me at a supplier or catalogue with a good range of small
p-clips?
Spehro Pefhany
plan.
them is "NXI".
p-clips?
http://www.mouser.com/catalog/specsheets/EPD-200464.pdf
Best regards,
Spehro Pefhany
