Sir Clambake . . . . . . . . . .
Ahhhhhh Sooooooo, you are now coming forward with the much needed info.
REFERENCE:
That pot assemblies switch connections are the YELLOW CIRCLES, the RED circles were just differentiating from the non significant pot support mounting brackets.
Mamma- san certainly done some SLOPPY soldering on ALL of those joints around that area.
Looking at the GREEN path and my broken trace X in YELLOW, see if your opening of that circuit and using the closing of that circuit path doesn't then accomplish your desired
remote controlling .
Except this time if you have the remote switch closed and adjust the pot for optimum /desired setting, afterwards, the unit should come on as soon as the remote switch is closed.
AS the unit was . . . . that setting would have to be run up and approximated EVERY time you turned the unit ON with that pots adjunct main power switch.
From the minuscule size of that GREEN trace run . . . . . we can see that is being a a minor switching function . . . . .with the REAL POWER switching done elsewhere with a secondaryPOWER device..
If somehow that shuts down more than desired, the second suggested procedure's roadmap is as shown below.
It is effectively running the pot down to its minimum setting every time the YELLOW X path is opened with the remote switching.
Plan II:
73's de Edd
REFERENCE:
Plan II:
73's de Edd
