Thought I'd share this in case anyone out there is also having drone yaw problems.
I have an old "inherited from my son" Phantom 3 Advanced drone and have always struggled to pan, yaw, rotate (whatever you want to call it) slowly and smoothly. Even with all the available menu options set to minimum speed vs stick movement I found it hard to control smoothly. Touch the stick and it spun but keeping the stick in exactly the same place proved impossible.
To look into this I opened the the GL-300B remote controller to see what was what and found that the yaw control was simply a 2K potentiometer, with the stick centered on it. Move stick one way or the other and the resistance changed by just over 110Ω. I figured that if I reduced this, the drone would go much slower so I designed the attached circuit to basically put another up to 10K into each half of the existing pot.
The heart of the mod is a DPDT switch. In the OFF position it kept the c circuit how it was (you need this to be able to start the motors), but when ON it put the ganged 10K pots into the circuit. Now, by adjusting the 10 pots I can rotate from zero rpm up to the original.
Once completed I can now put the stick hard over, left or right, and control the yaw speed with the new potentiometer. Works a treat!
