Hello, sem.
I've been trying to put together a small, slow AC induction generator
for quite some time now, and may be ready to put this one to bed.
Yes, I know small self-excited induction generators (SEIGs) don't work
well, and neither do slow ones, but how small and how slow can you go?
I've got two of Burden's Surplus Center #10-1134 motors mounted back to
back with a pipe nipple in the end bells, and a threaded rod joins the
shafts. These are 400 rpm synch, and 225 rpm full load speed, 1/12 HP
motors running on 110 VAC, 1A full load.
One works as a motor to drive the other for generator tests.
These are split-phase permanent capacitor motors. The generator has its
main phase wired to a GC cap sub box in parallel with a 10/20/20
microfarad sub box I built. I find a capacitance of abou 25 ufd
provides best wave shape and output intensity, but there has been no
useable output.
What I am wondering is, when you drive an SEIG below synchronous speed,
should it output essentially nothing (just remanence induced voltage),
or should it, at such speeds, be well on its way to building up full
output?
I know a synchronous machine operates as a motor below synch speed and
a generator above. Does an SEIG show the same behavior, or does it
output zero at zero speed, with increasing output to some point above
synch speed at which it generates full output?
If the SEIG behavior emaulates the former, I have some hope for
success. If it is the latter, I'd better cut my losses now, and move
on.
Yours,
Doug Goncz
Replikon Research
Falls Church, VA 22044-2536
useable output.
output?
on.
Yours,
Doug Goncz
Replikon Research
