I have a S/P-dif signal which I send over cat.5 like this:
S/P-dif source - External USB audiocard. Where TOTX is tapped for TTL signal.
RS-422 TX (DS 26LS31)
RS-422 RX (DS 90LV032)
74HC14/Ph Cmos schmitt trigger
650 nm, 4°, 1000 mcd
S/P-dif TTL -> RS-422 TX -> cat.5 stp -> RS-422 RX -> Inverter -> LED
The TOTX module of the soundcard is tapped for it's TTL signal (verified with
scope). It then feeds the RS-422 transmitter chip which has 10 uF over
GND-Vcc @ 5V. Delivered to cat.5 sheilded with a 333 series resistance to
get from 5V swing downto 1V (approx).
At the RS-422 receiver the differential is terminated with a 100 ohm resistor.
And feeds the RS-422 receiver chip. Which controls the inverter input.
On the inverter one input is used to invert the original signal. Which is then
feeded into the rest 5x parallell wired outputs. That feed the LED with a
140 ohm series resistance towards ground.
The S/P dif signal duration is approx 300 ns. Where _rise_ flank is something
like 100 ns. Which is way to slow. Everything works rise/fall wise if LED is
disconnected (observed on scope).
Any ideas on how to solve this?
