My brother has a three phase generator which was involved in a fire. I replaced burnt out wires and a three phase rectifier. It works, glory be !
I have noticed that one slip ring is badly worn and the other is almost like new. I assume the difference is due to the different polarity. I would like to connect the brushes to reduce the wear on the worn slip ring.
Will the positive or negative brush wear the commutator the most ?
