Power an Arduno via slip ring?
In theory should be ok BUT there is the ever present problem of perhaps noise and requirement for extra power regulation.
If so it could possibly be overcome by transferring a higher dc level and regulate on-site so-to-speak.
Slip ring power transfer like anything with low voltage could create unseen/un-thought-of problems.
I totally agree.
Use e.g. a 9 V supply (the Arduino has an input for that) and additional filter capacitors (e.g. 1000 µF, 16V) on the rotating side of the contraption. The capacitor will help to span any short interruptions due to the slip rings, the Arduino will generate the required 5 V from the 9 V even if the 9V shows some noise.
What about using an ESP32 board. It is also very cheap and it has WLAN and Bluetooth functionality. So data i/F should be no problem. As to the power supply I do fully agree with Harald.
As I understand it the Arduino is meant to be placed onto the rotating part of the contraption and the issue is all about uninterrupted power transfer.
