Rich Grise
ChairmanOfTheBored wrote:
Show us one, then, along with the detailed theory of operation.
Otherwise, shut up and go away.
Thanks,
Rich
No, it was 60Hz ac, 115kV. I know because they asked
us if we'd be affected by the radiated magnetic field,
being only 100-feet away from our labs, and they and we
undertook an analysis, which showed we were OK about it.
(I had suggested they twist the "wires" but that didn't
go over well, they didn't want to twist four conduits.)
ChairmanOfTheBored said:If they were in heavy lead jackets, it is very likely that
there would have been no radiated EMI even a few feet away.
More like twisted brains.
No that's wrong: neither the lead nor any other shield
would help to reduce the 60Hz magnetic field strength,
which comes from the magnitude of the ac current, and
the separation (and lack of twist) of the cables. As
it happened, we found the strength of the field in our
labs was a bit weaker than from our own poorly-done
electrical-conduit wiring. Which we had already dealt
with in sensitive experiments.
**** you, you fucking idiot. Hey, asswipe... over here, we
CAPITALIZE
the word I, you uneducable fucktard!
I do not have to compare anything, and I do understand. I built
HV
power supplies for the last ten years, asswipe.
A TV deflection circuit is NOT a flyback supply, idiot. The
flyback in
a TV is in the ANODE supply, you stupid ****.
You're a goddamned idiot. Nice assumption there, you fucking
retard.
That's like me saying "since you assume, you MUST be retarded."
Guess
what, dipshit? My remark is far closer to being correct than your
is or ever could be.
IF you even knew what a collapsing magnetic field does, you MIGHT
understand. The problem is 100% yours, idiot.
** More accurately and confusingly, what is a "pant", what is aRich said:The _earliest_ TV sets didn't need HV - they had a light bulb and
a perforated disk.
If there's only one TV, why is it called a "set"?
Why do they wear a _pair_ of panties but only one bra? ;-)
COTB posted, God only knows why: ....
It is inseparable from the horizontal deflection circuit.
"Commonly" Try ALWAYS! Long spans between tie points ALWAYS require a
steel carrier strand.
Even long cable TV coax runs need a steel carrier strand to keep them
from damaging the coax at the tie points. Not talking about hard line
here, as that gets bundled to a STEEL carrier strand as well!
**** you, you fucking idiot. Hey, asswipe... over here, we CAPITALIZE
I do not have to compare anything, and I do understand. I built HV
A TV deflection circuit is NOT a flyback supply, idiot. The flyback in
Of course it's a flyback. A single tube or transistor drives the
horizontal deflection coil and the HV transformer simultaneously. It's
sort of a neat coincidence that the same drive waveform works for
both.
The earliest b&w teevee sets had a separate, 60 Hz transformer-based
anode supply, operating at low kilovolt level. The dual-use flyback
trick made higher voltages affordable.
Rich Grise said:If there's only one TV, why is it called a "set"?
Almost always true, Joseph, but even if it weren't, that does not mean
that the deflection circuit is NOT a flyback circuit. Even the
vertical deflection circuit is a flyback circuit. I did once have a
monitor in which the HT supply was a completely separate unit, but
that's pretty rare. But for sure, the magnetic deflection circuits
are designed as flyback circuits to rapidly reset the magnetics for
the start of the next scan.
It's
both.
a perforated disk.
-- Gallagher
No, Johnny. SOME designs are flyback circuit driven. Some are not.
No, Johnny. In a flyback circuit, that is how SOME of them are driven.
There are plenty of other types of anode supplies in use that are NOT
flyback driven.
Special relativity is included in some cases as well. That still doesn't
mean that all anode supplies for all TVs are flyback circuit driven,
idiot.
COM for consumer devices is one thing. Commercial and industrial, as
well as military applications used other, more hardy methods.
I have made NON-flyback driven anode supplies for the steady cam
monitors in use on nearly all of Hollywood's steady cams. NOT a flyback
anode drive. It uses the same high brightness, daylight viewable
Thompson tube used in the F-4 Phantom.
For Hughes Aircraft in flight theater projectors. NOT a flyback anode
drive.
For General Electric medical imaging CRTs. NOT a flyback anode drive.
All are high reliability applications. All are not flybacks.
"scissor", and what is a "plier"?
We were talking about CRTs. ALL CRTs.
