E
EdV
From a previous post by Terry Given in "Resistor Current Handling
Capability" circa Thurs, Feb 26 2004 :
"This is a common reliability problem with power electronics -
"designers"
often neglect peak pulse power in MOSFET gate resistors - I saw one
design
with 4.7Ohm Rg, +12V Vg i.e. 31W peak, using 0805 resistors that failed
after a short time, causing catastrophic failure; so much damage was
done
each time that the root cause was totally obscured, and the "designer"
could
not stop it happening. oops. "
I am the lowly test engineer with the 10 fets in parallel test question
from several months ago. I the process of getting my head around how
hard I can pulse my 10 ohm gate resistors when one side itied to
ground. I read Terry's above note.
Anyone care to elaborate or point me to a good app note regarding
sizing Mosfet gate resistors?
The board I am testing (yes "they" decided the mosfets need to be
individually turned on. . .I knew "they" would) looks suspicously like
"oops".
Thanks much,
Ed V.
"designers"
design
done
could
"oops".
Thanks much,
Ed V.
