JackShephard
That's possible, I've had that happen before where
the leads pulled out enough to loss connection.
it was a batch of diodes with bad bonding
on the leads
You fucking retard.
on the leads
Tony said:ESD? Were the contacts connected to "external" signals?
How many times have I told you to stop talking to yourJackShephard said:JackShephard looks in the mirror.
"You fucking retard"
self? I'm glad you're finally coming to terms of what you are.
Are you now ready to join the human race?
maybe you should be using faster switching diodes?
also, I do know if the relay chatters it can heat up
diodes.
ian said:An application note from a relay manufacturer that I read a while ago
suggests a small signal diode in series with a zener.
Apparently if just a diode is used, the emf due to collapsing field can pass
enough current round the diode/coil circuit to cause faltering contact
separation and contact burn. There are other serious issues but I'd have to
search out the appnote to remind me what they are.
The zener should be wired so it would forward conduct with the transistor on
and the small signal diode in series pointing the other way to prevent that
happening, a guesstimate of Vz might be about 60% of the transistor's
breakdown voltage.
Paul Hovnanian P.E. said:
It's the energy storage, proportional to inductance and square of
the current, that matters. A 200 mA coil on a reed switch
has much lower stored energy than a 50 mA coil on a frame
relay. When you're using more current than the (average)
rating on your diode, it only succeeds if the temperature
spike doesn't melt anything.
Tony Williams wrote:1N4148s have a maximum reverse recovery time of 4ns. 1N400x diodes are
around 1,000 times longer.
Do tell.. how would that work?
Best regards,
Spehro Pefhany
you get contact bounce on the relay.
Was that suppose to be a joke?Spehro said:1N4148s have a maximum reverse recovery time of 4ns. 1N400x diodes are
Best regards,
Spehro Pefhany
Matt said:
I've known quite small relays to 'take out' 1N4148s, 914s etc.
Matt said:I am controlling the coil of a relay using a switching transistor. To
protect the transistor I intend to use a freewheeling diode in parallel
with the coil. I'm not sure of the issues in specifying the diode.
My impulse is to simply use a 1N4007
http://www.fairchildsemi.com/pf/1N/1N4007.html
(1000V peak repetitive reverse voltage, 1.0A average rectified forward
current) because it is common, cheap, and seemingly the most heavy-duty
of the 1N400x line. Would that be a good choice for about any
PCB-mounted relay?
John Popelish said:The absolute minimum repetitive surge current rating for the
diode is the steady state current for the coil, under the
highest supply voltage. If the diode is rated for a
continuous current equal to or greater than the coil
current, the brief inductive quench can't possibly overheat
the die.
If the contacts operating the relay become dirty or the control
transistor begins to oscillate, then you will get repetitive surges at
quite frequent intervals. It is better not to rely upon the
single-pulse surge current rating of the diode.
A diode with a continuous rating equal to (or greater than) the maximum
coil current will give peace of mind under all possible conditions of
operation and mis-operation.
