Jamie
OK, I think I have it visualized as to what you're doing.serpa4 said:Please, I need help. I just ran 12v straight to the fan and it ran on
high. No problems with interference. With that out of the way, I
decided to not put those magnet things on the motor wires. However, I
did put them on all the wires from the water/meth controller with no
luck. Its strange that the controller works fine when the fan is on
high and medium, but only interferes when the fan is on low.
1) Should I put capacitors on the fan motors? If so, what size, type,
etc.
2) What should I try next?
Thanks in advance for any help.
You have a PWM drive and it isn't connected directly to the
terminals of the motors ?
Assuming this is correct, in effect, you are radiating strong
EMF waves under the hood. Adjacent wiring is becoming an R.F.
receiving transformer and there for, influencing the lines of other
equipment.! Especially things that have low current sensor transmission
lines will mostly be whacked.
What you need to do is have the output of the PWM circuit pass through
an inductor circuit with a smoothing cap on the other side.
for proper size selection, knowing the carrier frequency of the
PWM circuit helps.
