Hi guys, I did some electronics years (and years) ago but now find myself with a little problem.
Last year I bought a satellite box, it is brilliant but in the summer has a tendency to over-heat. The manufacturer built in a header for a fan that is supposed to be 5v, however it turned out the header only outputs 3v. The 3v isn't enough to drive the fan, so I have fitted a fan using 5v from the usb connector and this works fine apart from the fact that the fan is on permanently as opposed to the fan header that can be temperature controlled.
So my idea is to make a 3v to 5v relay using the fan headers 3v to switch on and off the usb's 5v supply.
Can anyone help with a diagram and parts? I am in the UK
thanks
nemo
thanks
nemo
