You require sodium hydroxide my good man.
Recipes are as follows:
1 tea spoon to 1Ltr for developing (use @ around 30°C).
2 tea spoons to 1Ltr for stripping (use at around 30°C, or 35-40°C for faster strip time).
For the developer, warm the solution to somewhere around the 30°C mark and use a brush to develop rather than fully immersing the board. It can take longer this way if the solution is below optimum tempreture, but if you haven't got a thermometer and overshoot the mark, it can strip more than you'd want pretty quick so it's best to have it in hand just in case it needs to be quickly dunked in water to stop the process.
Sodium hydroxide developer also works for solder resist film too and I use the same process as described above.
<edit>Forgot to say I etch my own boards and in the beginning I did look into alternatives myself but the sodium (which I get from ebey) gives the best results IMHO. I didnt get on with the etch resist film, kept getting bubbles in it, even after checking for dust/temp/dirty rollers. Doesn't happen with the solder resist film so switched to pre sensitised boards instead.
