Simple question, is this correct?
Unsure as to whether this answer is correct? - Cheers
I have not worked through the circuit but I do not think it right.
Also no gate output should be shorted to ground.
There are two questions that must be answered:
- 1. Does Vgs of the MOSFET need to be high or low to turn on the detector?
- 2. Which side of the bi-stable latch goes high or low when the button is pressed?
When you can answer those questions, make that connection.
