simple one-shot pulse detector circuit needed
Hi all,
I seem to recall from distant memory that it's possible to make a pulse detector out of two of transistors and a few resistors, but I can't find the circuit anywhere. Searches keep throwing up stuff about astable multivibrators and nand gates and that's not what I'm looking for.
Just need to be able to detect a 1 second pulse of 5v on an otherwise 0v line. The pulse comes only after several days of inactivity and should turn an LED on permanently. No reset required and any subsequent pulses must *not* turn the LED off again, so it's operating like a bistable latch (if that's the right term).
Can anyone assist?
Tia.
G
George Herold
Hi all,
I seem to recall from distant memory that it's possible to make a pulse detector out of two of transistors and a few resistors, but I can't find thecircuit anywhere. Searches keep throwing up stuff about astable multivibrators and nand gates and that's not what I'm looking for.
Just need to be able to detect a 1 second pulse of 5v on an otherwise 0v line. The pulse comes only after several days of inactivity and should turnan LED on permanently. No reset required and any subsequent pulses must *not* turn the LED off again, so it's operating like a bistable latch (if that's the right term).
Can anyone assist?
Tia.
I assume there is another power line to run it from (+5 V). I don't
know the transistor circuit, but how about a S/R flip flop?
George H.
Michael Black
Hi all,
Can anyone assist?
Tia.
An SCR would do it, once triggered it only turns off if it loses power on
the anode.
You can get the effect of an SCR with two transistors, at least for this
purpose. I can't remember, but doing a search for something like that
should do it.
Michael
G
George Herold
Version 4
SHEET 1 880 680
WIRE 16 -192 -496 -192
WIRE 160 -192 16 -192
WIRE 16 -144 16 -192
WIRE 160 -144 160 -192
WIRE 16 48 16 -64
WIRE 160 96 160 -64
WIRE 160 96 80 96
WIRE 160 128 160 96
WIRE 160 224 160 192
WIRE -352 272 -400 272
WIRE -208 272 -272 272
WIRE -128 272 -208 272
WIRE 16 272 16 144
WIRE 16 272 -64 272
WIRE 96 272 16 272
WIRE -496 304 -496 -192
WIRE -400 304 -400 272
WIRE -208 320 -208 272
WIRE -496 432 -496 384
WIRE -400 432 -400 384
WIRE -400 432 -496 432
WIRE -208 432 -208 384
WIRE -208 432 -400 432
WIRE 160 432 160 320
WIRE 160 432 -208 432
WIRE -496 496 -496 432
FLAG -496 496 0
SYMBOL res 144 -160 R0
SYMATTR InstName R1
SYMATTR Value 39
SYMATTR SpiceLine ""
SYMBOL npn 96 224 R0
SYMATTR InstName Q1
SYMATTR Value 2N3904
SYMBOL pnp 80 144 R180
SYMATTR InstName Q2
SYMATTR Value 2N3906
SYMBOL diode -128 288 R270
WINDOW 0 32 32 VTop 2
WINDOW 3 0 32 VBottom 2
SYMATTR InstName D1
SYMATTR Value 1N4148
SYMBOL res -256 256 R90
WINDOW 0 0 56 VBottom 2
WINDOW 3 32 56 VTop 2
SYMATTR InstName R2
SYMATTR Value 68k
SYMBOL cap -224 320 R0
SYMATTR InstName C1
SYMATTR Value 47
SYMBOL LED 144 128 R0
SYMATTR InstName D2
SYMATTR Value NSCW100
SYMATTR Description Diode
SYMATTR Type diode
SYMBOL voltage -400 288 R0
WINDOW 3 24 96 Invisible 2
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName V1
SYMATTR Value PULSE(0 5 1 1u 1u 1 0 1)
SYMATTR Value2 ""
SYMBOL voltage -496 288 R0
SYMATTR InstName V2
SYMATTR Value 10
SYMATTR Value2 ""
SYMBOL res 0 -160 R0
SYMATTR InstName R4
SYMATTR Value 1000
TEXT -530 520 Left 2 !.tran 3 startup
Nice... but I had to reduce C1 from 47 Farads to 47nF :^)
George H.
mike
The 1 second requirement significantly complicates the solution.
If any old pulse will do, use a latching relay...either magnetic latch
or feedback from the contacts.
As always, the devil is in the details.
How much current can you get out of the 5V pulse?
What voltages are available when the pulse is not present?
How do you expect to reset the thing?
What are the specific details of the 1 second requirement?
Timing accuracy and boundary conditions?
Assume you wouldn't have mentioned it if it weren't important.
[snip]
Along these lines, what would the group recommend for a weatherproof
switch to detect that a yard gate is not closed all the way?
magnet/reed switch from a burglar alarm door/window ajar sensor.
Spehro Pefhany
... or just a resistor (eg. 4K7) to drive the gate of a 2N5064, in turn
drive an LED with series resistor (4 parts). It will detect a positive
pulse of any length greater than a couple microseconds by latching on,
and thence cease to care about the state of the input, so the LED will
stay on until the power is cycled.
[snip]
Should be battery powered sensors with RF interface available for
security.
mike
security.
I missed that part of the specification.
Probably want three or more magnetic sensors physically placed
and logically connected to insure that it can't be spoofed by
a magnet without intimate knowledge of the design.
Encase the bullet-resistant box in concrete.
Probably want to put a signal into the razor wire so you can use
it as a proximity sensor. Maybe a satellite phone to call the
cops when the phone lines get cut. And a bluetooth
connection to the alarm system with an encrypted heartbeat
so it can't be jammed.
Probably want at least one guard dog with a wireless heart rate
sensor just in case they get put to sleep.
Of course, destroy all documentation and eliminate everybody
you ever discussed it with. Crush the hard drive.
Grind it up into dust and scatter it at least 10 miles off shore.
If security isn't the primary requirement, there are lots of devices.
The Powerhouse MS13A is a X-10 wireless PIR motion detector.
You could hack a relay into that and get motion plus gate detection.
They have other alarm sensors, but I don't know the numbers.
There are devices designed to alert you when your mailbox door is opened.
Driveway occupancy sensors.
Wireless doorbells.
Garage door openers.
RF TV remotes.
And my personal favorite...close the damn gate. ;-)
Spehro Pefhany
And the gate is steel. Maybe the other way around, a coil whose
inductance changes with gate position?
...Jim Thompson
There are waterproof inductive proximity sensors with all the
circuitry in a little tube.
phaedrus
Version 4
SHEET 1 880 680
WIRE 16 48 16 -64
WIRE 160 96 160 -64
WIRE 160 96 80 96
WIRE 160 128 160 96
WIRE 16 272 16 144
WIRE 16 272 -64 272
WIRE 96 272 16 272
FLAG -496 496 0
SYMATTR InstName R1
SYMATTR Value 39
SYMATTR InstName Q1
SYMATTR InstName Q2
SYMATTR InstName D1
SYMATTR InstName R2
SYMATTR Value 68k
SYMATTR InstName C1
SYMATTR Value 47
SYMATTR InstName D2
SYMATTR Type diode
SYMATTR InstName V1
SYMATTR Value2 ""
SYMATTR InstName V2
SYMATTR Value 10
SYMATTR Value2 ""
SYMATTR InstName R4
SYMATTR Value 1000
Can't get this to run for some reason, John. This is a LT spice
netlist? Just get the following error message: "multiple instances of
SYMATTR" Since someone else on this thread seems to have got it going
(albeit with a slight mod to a cap value) I assume I'm doing something
wrong (not an unknown experience).
phaedrus
the anode.
should do it.
   Michael
Yes, I'm aware a SCR would be ideal, but I only have great fat
thumping big ones lying around which would be a waste for such a small
signal application.
Malvino's book Electronic Principles shows the kind of thing I'm
talking about, I've just discovered, at page 501. Vanishingly terse
explanation with no reference to it in the index or contents for some
reason. Uses a BJT PNP/NPN pair with bases and collectors shorted
together between them and one resistor in the Vcc line. I reckon this
should do the trick with any luck.
phaedrus
Here's the netlist of the Malvino design. Seems to run alright...
"ExpressPCB Netlist"
"LTspice IV Version 4.17"
1
0
0
"Part IDs Table"
"Q1" "2N3904" ""
"Q2" "2N3906" ""
"V1" "12" ""
"V2" "PULSE(0 5 1 1n 1n 1 1 1)" ""
"R_LOAD" "1200" ""
"Net Names Table"
"N003" 1
"N004" 3
"0" 6
"N002" 9
"N001" 11
"Net Connections Table"
1 1 1 2
1 2 2 0
2 1 2 4
2 2 1 5
2 4 1 0
3 1 3 7
3 3 2 8
3 4 2 0
4 2 3 10
4 5 2 0
5 3 1 12
5 5 1 0
G
George Herold
wrong (not an unknown experience).- Hide quoted text -
- Show quoted text -
Hmm, I just cut and pasted the whole thing into notepad... or pick
some other text editor.
Then save it with a .asc ending, into my ltspice/bin and run it.
George H.
Jasen Betts
a reed switch like used for alarms...
Jasen Betts
Hi all,
Can anyone assist?
just make an SCR out of your two transistors.
one resistor on the gate input and a series resistor to limit the LED
current.
phaedrus
On Tue, 20 Nov 2012 12:22:00 -0700, Jim Thompson
15:02 -0800 (PST), [email protected]
wrote:
Hi all,
I seem to recall from distant memory that it's possible to make a pulse detector out of two of transistors and a few resistors, but I can't findthe circuit anywhere. Searches keep throwing up stuff about astable multivibrators and nand gates and that's not what I'm looking for.
Just need to be able to detect a 1 second pulse of 5v on an otherwise0v line. The pulse comes only after several days of inactivity and should turn an LED on permanently. No reset required and any subsequent pulses must *not* turn the LED off again, so it's operating like a bistable latch (ifthat's the right term).
Can anyone assist?
Tia.
Now make it blink miser-style, as in LM3909 ;-)
Version 4
SHEET 1 880 680
[snip, details in...]
Message-ID: <[email protected]>
                                       ...Jim Thompson
Once tripped, have it blink to save power.  (I'm thinking battery
power.)
                                        ...Jim Thompson
I gathered that, Jim. Good suggestion on your part; I just can't get
that link to bring up any results for some reason. :(
phaedrus
George H.
I must be having a really bad day, George. Ain't got no such folder on
my system!
mike
Actually I want to know that it was opened. Got a Mexican claiming he
worked when he didn't :-(
...Jim Thompson
You keep adding requirements to the spec.
Often, it's useful to monitor the thing you want monitored.
Monitoring attendance is no guarantee that you actually get work.
Stated another way:
If you can't tell if the work was done, you're paying for work
you don't need.
phaedrus
Here's the circuit list again, just in case...
Version 4
SHEET 1 880 680
WIRE 16 0 16 -64
WIRE 160 48 160 -64
WIRE 160 48 80 48
WIRE 160 80 160 48
WIRE 160 176 160 144
WIRE -352 224 -400 224
WIRE -208 224 -272 224
WIRE -128 224 -208 224
WIRE 16 224 16 96
WIRE 16 224 -64 224
WIRE 96 224 16 224
WIRE -496 256 -496 -192
WIRE -400 256 -400 224
WIRE -208 272 -208 224
WIRE 160 320 160 272
WIRE -496 432 -496 336
WIRE -400 432 -400 336
WIRE -208 432 -208 336
WIRE 160 432 160 400
FLAG -496 496 0
SYMATTR InstName R1
SYMATTR Value 330
SYMBOL npn 96 176 R0
SYMATTR InstName Q1
SYMBOL pnp 80 96 R180
SYMATTR InstName Q2
SYMBOL diode -128 240 R270
SYMATTR InstName D1
SYMBOL res -256 208 R90
SYMATTR InstName R2
SYMATTR Value 68k
SYMBOL cap -224 272 R0
SYMATTR InstName C1
SYMATTR Value 47
SYMBOL LED 144 80 R0
SYMATTR InstName D2
SYMATTR Type diode
SYMBOL voltage -400 240 R0
SYMATTR Value2 ""
SYMATTR InstName V1
SYMBOL voltage -496 240 R0
SYMATTR Value2 ""
SYMATTR InstName V2
SYMATTR Value 10
SYMATTR InstName R4
SYMATTR Value 1000
SYMBOL res 144 304 R0
SYMATTR InstName R3
SYMATTR Value 39
TEXT -488 456 Left 2 !.tran 3
Now, here's what to do:
1. On your newsreader's screen, copy the entire list, including
   "Version 4", to the clipboard by selecting all the text, then
   pressing CTRL-C.
2. Launch Word Pad or any other plain ASCII text editor, and paste the
   circuit list into it by  pressing Ctrl-V.
3. Using "Save As", assign a filename to the list
   (say, "1s pulse detect.asc") and save it to any folder you like.
   Make _sure_ the file has a .asc filename extension.
4. Now, navigate over to the folder to where you saved
   "1s pulse detect.asc", and left click on the file.
   If .asc files are associated with LTspice in your box, then LTspice
   will find it and you'll see the schematic pop up.
   If that doesn't happen, launch LTspice, navigate to the file, and
   left-click on it.
   The schematic should appear, and then you can play with the circuit
   'til your heart's content.
5. Enjoy! :)
Finally! Thank you, John. Don't know what the problem is this end, but
your list combine with my version of LTS generated a corrupted
schematic with several components rotated and out of position!
Anyway, I was able to reconstruct the corrupted diagram and it now
works fine. Thanks again!
