Thanks guys, I am about to order the batteries from manafont.
My choices are 3 individually protected batteries (easier, guaranteed fit)
or
3 unprotected batteries (same specs) in parallel all connected to ONE PCM (pictured below)
Note:as you can
see below the original battery (NG) was one (i think there are 3 cells in there because there are creases in the metal at 1/3 1nd 2/3 from each side) with a single PCM on right (burned out, I checked it)
My concern is overcharge and discharge protection maybe being uneven with the individually protected batteries. Does it even matter?
Note to donkey, thanks and I see what you're saying but I should add that this device is safety equipment so I feel that I must stick to the original specs as close as possible.
