simple current limiting to 2A with TIP122
I don't understand.
Are you driving 8 x 8 digit 7 segment displays?
Is the TIP122 the driver for the segments or for the digits?
Remember that in a multiplexed display only a single digit is on at any time. The digits are scanned through quickly to give the illusion that all are on.
no we have 7 TIP122 in circuit and 1 tip122 limit current . we drive simple 1 7segment in floor we have (a.b.c.d.e.f.g) with common +24 and show number p to 8
Come on
i need a circuit limit current to 2A have Signal LED TOO
I can't see where you get 2A from. 7 segments times 30mA is 210mA. A limit of 250mA would be fine.
Or just use a 500mA fuse.
I have think that each segment will take 30 mA
Seven segment was a 210 mA current I have 8 Seven Segment result 1680 mA
and a current limiting 2A need
So how do the Chinese Limit the current with TIP122 without cooling ?
Possible short circuit too much
But at the time of short circuit LED short circuit on the field and we realized getting short-circuited
You really do not care @(*steve*)
i don't want use fuse i want use current limiter
You really can't explain what you're doing.
You say you need a 2A current limit, yet all the explanation I've been able to get out of you suggests that 1/8th of that current is sufficient (which, by the way, goes a long way to explain why someone would attempt it without a heatsink).
It seems that you don't understand what you're doing, and if that is the case, I'm not willing to lead you further astray.
8 Seven Segment are Parallel i dont want limit per segment or 1 7segment i want limit for total 8 7segment
Do not change issue You do not understand me
IF you have limiter 2A with Signal LED Offer it , otherwise Do not ideas
