E
ectoplasm
I want to build a simple audio mixer (adder) (from stereo line inputs)
of good quality and low energy consumption. I found this simple
design:
http://www.aaroncake.net/circuits/mixer1.asp
and I also found this one that also uses a transistor:
http://www-fa.upc.es/websfa/lab/111/audio/audmixer.txt
Q1: would the simple design work well, or is it just a theoretical
example? Otherwise, why would the second design add a transistor? (Q2)
The second design's webpage says:
"If two of these circuits are made in the same enclosure for
stereo, then there can be a single power supply to run both of them.
There should be a resistor in series with the incoming 9V+ lead so as
to minimize crosstalk, and reduce the PLOP when it's powered on."
Q3: How big should this resistor be (Ohm)?
Q4: So each of the two stereo's mixers circuits should have their own
resistor in series with / connecting to the battery?
Q5: The second design uses a lot more power because the transistor
draws a current while it's not used. Battery power wouldn't be
feasible, right?
design:
feasible, right?
