Shure M105E phono cartridge
Tim Schwartz
Hello all,
I've got a customer's turntable here with a Shure M105E p-mount
cartridge in it. The stylus is fine, but the cartridge itself has an
open winding. I've seen this in Audio Technica and Grado cartridges
over the years, but never before in a Shure. Any chance you've got a
good body without a stylus you'd part with? (In the USA preferred. I'll
gladly pay shipping.)
Thanks!
Tim Schwartz
Bristol Electronics
David Nebenzahl
Cue N. Cook with nonsense about opening up cartridge and repairing open
winding ... or at least endless speculation about *why* it failed ...
Meat Plow
N. Cook obsession noted. And laughed until breathless at.
N_Cook
The fashion in killing has an insouciant, flirty style this spring,
with the flaunting of well-defined muscle, wrapped in flags.
- Comment from an article on Antiwar.com (http://antiwar.com)
False , I've never opened a magnetic cartridge. Only crystal cartridges ,
where the crystal is hygroscopic in the damp UK and does not survive 40
years and that includes NOS of course. They revert to paste or powder.
Matter of replacing with piezo-ceramic transducer
Dave Plowman (News)
On 11/16/2010 2:41 PM Tim Schwartz spake thus:
Not quite sure why you find this something to jibe at. I love trying to
fix things which most would simply replace. Gives a great deal of
satisfaction putting one over on the makers.
N_Cook
*Why don't you ever see the headline "Psychic Wins Lottery"?
Dave Plowman [email protected] London SW
To e-mail, change noise into sound.
Faced with the OP situation I would suspect an owner has removed a connector
using pliers and has twisted the pin in the plastic and so internal broken
wire at the output. I would .5mm disc grind in and/or melt in around a
suspect pin. Then consider chucking if break is within a coil, but would
certainly explore the construction because I don't think I've seen inside a
magnestic cartridge.
David Nebenzahl
connector using pliers and has twisted the pin in the plastic and so
internal broken wire at the output. I would .5mm disc grind in and/or
melt in around a suspect pin. Then consider chucking if break is
within a coil, but would certainly explore the construction because I
don't think I've seen inside a magnestic cartridge.
See? See? What did I tell you?
Look; I'm as DIY as anybody. I've fixed, or at least have tried to fix,
all kinds of things, some of which many people would consider hopeless.
But I recognize there are limits. N. Cook does not.
Repair a lousy magnetic cartridge? Are you serious? I'll bet he would
actually get out his .5mm disc grinder if this equipment landed in his
"shop". Sheesh.
Hey, he's free to broadcast the results of his bodgering here as much as
he likes. I'm free to ridicule him. See how that works?
N_Cook
"shop". Sheesh.
This usenet group is called sci.electronics.repair not how you would like it
sci.electronics.chuck_it_and_buy_new
Dave Plowman (News)
Michael A. Terrell said:
So? There is a fine line where it is a matter of ego, instead of
repairing something.
Really? This comes up all the time on a one make classic car forum I read.
I'll open up things like switches and relays and clean them if they give
trouble. Most there seem to think it's better to buy new or used. And of
course 'new' parts that are 25 years old can have corrosion on the
contacts too. With a hobby, it doesn't matter much if it takes time to fix
something like that out of all proportion to the cost of replacement. It's
the satisfaction you get from doing it which is priceless.
N_Cook
*Wedding dress for sale. Worn once by mistake.*
The silliest, normally uneconomic, job I ever did was for someone with
cerebral palsey . (first time I came across that situation where you can
comprehend someone's speech only if you do not look at their face and get
miscued by distorted vestigial "lip-reading").
He drove (as far as i could tell with only the use of 2 fingers on a heavily
modified car) 15 miles and back , twice , for me to repair the motor of a
silly 12V fan that plugged into the car cigarette lighter. This fan kept his
pet dog/ gofor/ assistant happy sitting in the passenger side foot well. It
had a unique clip arrangement so any old fan would not do. Before the days
of mobile phones so he had a distinctive car horn beep sequence and I would
go out to him. It apparently took about 1/2 hour , with assistance from his
dog , to get in and out of the car.
Tim Schwartz
Hello again all,
When I posted my request, I was trying to save a customer some money on
a repair that was getting expensive.
ONE person actually sent me an e-mail with some useful info on a web
site that had a similar cartridge at a reasonable price, and thanks to
him for that.
I had NO INTENTIONS of starting a thread on bashing an individual.
IF YOU CAN'T STAND POSTINGS FROM A CERTAIN INDIVIDUAL (including me)
DON'T COMPLAIN ABOUT IT. Instead, either skip over posts from that
person, or learn to use your browsers' features and block posts from
that person.
While I do find some people attempt repairs that I would not, I also
find that sometimes they have something useful to say, or have found an
reasonable way to repair something that I thought could not be repaired
for less than the cost of replacement.
Regards,
Tim Schwartz
Bristol Electronics
P.S. I had my brands wrong. The cartridges I used to see open windings
in all the time was Micro Acoustics, not Audio Technica. My apologies
to Audio Technica. (My memory is getting sort of foggy.)
Original post:
Hello all,
Thanks!
Tim Schwartz
Bristol Electronics
Dave Plowman (News)
get miscued by distorted vestigial "lip-reading"). He drove (as far as i
could tell with only the use of 2 fingers on a heavily modified car) 15
miles and back , twice , for me to repair the motor of a silly 12V fan
that plugged into the car cigarette lighter. This fan kept his pet dog/
gofor/ assistant happy sitting in the passenger side foot well. It had a
unique clip arrangement so any old fan would not do. Before the days of
his dog , to get in and out of the car.
Great. When someone takes that effort to get things done the least one can
do is reciprocate.
About 20 years ago I made up a deaf aid for a favourite uncle. He did have
two very expensive pro deaf aids but didn't like them one bit. He was
house bound so only usually had one or two visitors at a time.
I made up a small battery amp with a compressor and peaked at around 2kHz.
Driving a set of ordinary walkman headphones. And a lapel mic on a long
lead. With that clipped on the visitor he could at long last carry on a
conversation easily.
I got the idea because he used headphones to listen to the TV and radio,
and said they were so much better than using his deaf aids with their
speakers.
Meat Plow
Hmm, that's odd: I remember you posting earlier in this thread:
Guess we just caught you in an off moment, eh?
Unlike you I never have off moments. You're an asshole, just admit it and
you will feel better.
Meat Plow
Hello again all,
him for that.
It's not your fault. There are a few megalomaniacs in this news group
that will jump at the chance to bash others. Example: Dave Nebenzahl
using your post to belittle N. Cook. No reason for it besides a childish
ego thing.
David Nebenzahl
To the O.P.: as the one who took the thread off on a tangent, be assured
that I had no intentions of implicating YOU here. Don't worry; you are
blameless.
ego thing.
Careful, Meathead: after all, 'twas you who wrote in this thread:
Or are you now claiming that this was posted by an imposter?
Meat Plow
blameless.
Yes I wrote that you dumb-ass. It was a reply to your obsession with N.
Cook. Now, **** off child.
David Nebenzahl
OK. As always, your exemplary good manners and your with and mastery of
the language are an inspiration to us all.
David Nebenzahl
Should be "your WIT"; I gueth I wath lithping there.
