CW
The bead on a wire idea works. It has been used frequently in crystal
radios.
radios.
Dave said:The antenna does indeed seem to be working great, and the radio is not
operating too shabily either as it is only the "background noise" I am
trying to reduce. I hooked a 100 mH RF choke up to it with good results,
and am planning on adding another one or two similar devices in an effort to
cut down on higher frequency interference. Question: how would I ground
this antenna?
I have a grounding rod right outside the window, but don't
know what to hook it too. The negative battery terminal?
This radio does
have an external antenna input, but that has a plastic ring around the
outside. Open to suggestions.
And thanks for the input RE purchasing a
new/used tuner.
dave
Rich Grise said:effort
Uh, you don't ground the antenna. You ground ground.The ground is like
a "return" path for the current induced in the antenna by the radio wave.
Probably. Any handy chassis ground will be fine.
The radio might be grounded through the power cord, if it's a 3-prong.
Otherwise, just a wire from the radio's chassis to the ground rod, or
even to one of the mounting screws of a grounded outlet.
As you seem to have mentioned, you have lots & lots of signal
strenth, so you actually might want to make your antenna even _less_
sensitive. What it sounds like you're looking for is selectivity,
and you do that with tuned circuits. Or you did back when I was
learning this stuff. ;-)
Hope This Helps!
Rich
Dave said:Yes, a tuned circuit, I am thinking. There is currently much more signal
than I need. Is an antenna tuner what I am looking for?
I hooked up 300 microhenries worth of RF choke, which reduces the entire
signal just a hair, but that is enough to knock the noise level down
considerably. I am not yet sure, but this *may* be all I need. BTW, did
some fiddling withe the anchor of the random wire, and decided it is more
like 45 - 50 feet total. I am planning on moving it, however, and placing
it under the eaves and off to the side of the aluminum rain gutter, which
may deflate it some. Right now I have signal to waste. That may change.
Thanks for the input. Working with RF is new to me.
Anytime you have to much signal and want to reduce it you employ anDave said:Yes, a tuned circuit, I am thinking. There is currently much more signal
{snippage}
If you don't care about reflections then you can make a quick and dirty
variable attenuator using a potentiometer from Radio Shack. The outer
shield of the coax goes to the same radio connection and one end of the
potentiometer, the other end of the potentiometer goes to the coax
center conductor and the potentiometer wiper goes to the radio input
where the coax center conductor would normally go. A 10K potentiometer
would be good to use.
Rich Grise said:Actually, if you've got good electrical conductivity, the aluminum
rain gutters themselves might make a passable antenna. Ground _one_
of the downspouts at the bottom end, and experiment with different
pickoff points along the length of the gutter. An antenna has
different impedances at different points along its length, based on
the wavelength of interest. And you'd add inductance and capacitance
as needed to make the whole thing resonant at the freq. you want.
(that's the philosophy of an "antenna tuner.")
It really wouldn't do any harm to look up some books on antennas
and stuff, like "The ARRL Antenna Book", and talk with practically
any radio amateur - those guys do this stuff all day long.
Cheers!
Rich
Telamon said:Anytime you have to much signal and want to reduce it you employ an
attenuator. For coax it would be composed of three resistors in a pie
network. You would select values that would cause the input and output
resistance of the attenuator to appear 50 ohms using the source and load
impedance of the antenna and receiver so it would not generate
reflections. Additionally the resistor values would provide the voltage
division required. All calculations use ohms law. Since the radios S
meter basically is a reflection of the signal voltage a 6 dB attenuator
would cause the meter deflection to be about half what it was without
the attenuator.
She absolutely hates
having a piece of wife laying across the roof, and can't wait until I
fix it in place underneath the eaves.
-=jd=- said:There's a few different ways I could interpret that!!
-=jd=-
LOL! I meant to say "a piece of WIRE..." Guess I was thinking
something else.
Dave
[email protected]
..= = = "Dave said:I recently hooked up a thirty-six foot (plus or minus a couple of feet)
piece of four-stranded wire with alligator clip to the internal "whip"
antenna of my portable shortwave receiver, for the extra performance such a
device offered. It works so well that I now cannot usually use my "DX"
setting because of all the background noise (sounds like hundreds of other
broadcasts vying for attention.) I don't know the frequency source of all
this background noise, but would like to filter out as much of it as I can.
One manufacturer of a similar "wind-up" antenna adds a capacitor to the wire
in order to lower the resonance frequency of the wire. If I were going to
try something similar (adding a capacitor, in series) in an attempt to bring
the resonance of the wire down into the 30 MHz range, what size (roughly)
capacitor should I use? Should I just try a few with different ranges, or
does anyone here have any suggestions?
TIA
Cross-posted between sci.electronics.basics and rec.radio.shortwave
Dave
[email protected]
RHF said:DAVE,
So you have a Sangean ATS -505 and your 'problems' are Antenna
Overload and Noise Levels.
* Consider a 'smaller' shorter Antenna will reduce the overload problems.
* Consider a Low Noise Antenna Design will reduce the noise problems.
{LOW NOISE SWL ANTENNA - popularized by John Doty}
http://groups.yahoo.com/group/Shortwave-SWL-Antenna/message/2
http://www.anarc.org/naswa/badx/antennas/low-noise_antenna.html
For a simple 'external' Shortwave Antenna to use with the Sangean
ATS-505 'portable' Shortwave Radio, using the 1/8" Mono-Jack
External Shortwave Antenna Input. Consider a Random Wire
Antenna using a Matching Transformer and Ground for Low Noise
and Wide Range Frequency Coverage.
PARTS: Here is a simple SWL Antenna Idea using a few common
RadioShack TV Antenna type parts:
Catalog #: 15-1174 = 25~50 Foot 300 Ohm (Flat) TV Twin-Lead
Catalog #: 15-1230 = 75 to 300 Ohm Matching Transformer (2 Ea.)
Catalog #: 274-286 = 1/8" Mono (Phone) Plug
Catalog #: Catalog #: 15-1579 = 25~50 Foot Coax Cable with F Connectors
NOTE: This is an 'improved' Random Wire SWL Antenna using "TV"
Parts for 'reducing' Man Made Noise (RFI EMF) that is generated in
or near most modern homes/buildings.
EXTERNAL "OUTSIDE" SWL ANTENNA:
The Antenna [Loop] Element is Stretched outside Horizontally or
in the shape of an Inverted "L". The Antenna [Loop] Element is
formed by connecting the two ends of the Far-End of the 300 Ohm
TV Twin Lead. This forms a continuous single skinny horizontal
flat loop going out and back. This also represents a Balance
300 Ohm Load to match-up with the 300 Ohm Matching Transformer.
The 300 Ohm Leads of the Matching Transformer connects to the
Near-Ends of the Loop Antenna Element. The 75 Ohm F Connector
of the Matching Transformer is connected to the 75 Ohm Coax Cable.
The 75 Ohm Coax Cable acts as the Lead-In from the Outside to
inside the house to the radio shack. The other end of the 75
Ohm Coax Cable is connected to the 75 Ohm F Connector of the
Matching Transformer. The Radio-End of the Coax Cable F Connector
would connect to a 75 to 300 Ohm Matching Transformer; and then
into a 1/8" Mono-Plug to plug into the Radio.
NOTE: Using the 300 Ohm TV Twin Lead in a Skinny Flat Loop
Antenna should balance-cancel-reduce most man made noise and be
Omni-Directional.
GROUND: Find a Grounding Point within/about your dwelling.
Secure a good Grounding Point for your Radio and Antenna.
Run a Heavy & Short Ground Wire to your Radio. Locate the
Ground Terminal on your Radio. Attach/Secure the Ground Wire
to the Coax Cable and/or the Radio's Ground Terminal.
FWIW: This Antenna using common TV Antenna type parts should
be effective as SWL Antennas above 5MHz and beyond 30MHz.
iane ~ RHF
Some Say: On A Clear Day You Can See Forever.
http://groups.yahoo.com/group/Shortwave-SWL-Antenna/message/502
I BELIEVE: On A Clear Night...
You Can Hear Forever and Beyond - The Beyond !
TIA
Dave
[email protected]
RHF said:DAVE,
Omni-Directional.
iane ~ RHF
TIA
Dave
[email protected]
Just printed your instructions in prep for a trip to the store, and have
one question: The twin-lead is 300 ohm, connected to a 300/75 ohm
matching transformer, connected to 75 ohm coax. Then the coax is
connectect to another 75/300 ohm matching transformer, which is
connected to the 1/8" mono plug to plug into the external antenna jack?
Is the 1/8" jack a 300 ohm impedance connection? Somehow I thought it
would be 50 or 75 ohms, like coax. Do I need some 300 ohm coax to put
between the second transformer and the plug?
Thanks,
Dave
[email protected]
= = = "Dave said:Just printed your instructions in prep for a trip to the store, and have one
question: The twin-lead is 300 ohm, connected to a 300/75 ohm matching
transformer, connected to 75 ohm coax. Then the coax is connectect to
another 75/300 ohm matching transformer, which is connected to the 1/8" mono
plug to plug into the external antenna jack? Is the 1/8" jack a 300 ohm
impedance connection? Somehow I thought it would be 50 or 75 ohms, like
coax. Do I need some 300 ohm coax to put between the second transformer and
the plug?
Thanks,
Dave
[email protected]
RHF said:DAVE,
Omni-Directional.
iane ~ RHF
TIA
Dave
[email protected]
RHF said:DAVE,
At the Radio-End of the 75 Ohm Coax Cable "F" Connector you can
use a standard 75-300 Ohm Matching Transformer and then connect
it to a Mini-TV External Antenna Adapter. [ RadioShack {Canada}
Catalog #: 15-1148 = 75 to 300 Ohm Mini-Plug Adapter ]
MINI-PLUG-ADAPTER=> http://tinyurl.com/23nsh
FWIW: Some RadioShacks and other electronics stores have an "Adapter"
that directly connects an "F" Connector to a /18" Mono-Phone-Jack.
Please Note: That a 'connection' to a good earthen Ground is
needed to one of the "F" Connectors of the 75 Ohm Coax Cable.
You can use a #14 Wire with a RadioShack Catalog #: 278-002
Heavy-Duty Claw Insulated Test/Jumper Cable Sets. Or, simply
use several windings of bare wire wrapped around one of the "F"
Connectors with a small metal hose clamp to secure the wire.
iane ~ RHF
the plug?
Thanks,
Dave
[email protected]
ofRHF said:DAVE,
Omni-Directional.
iane ~ RHF
= = = I recently hooked up a thirty-six foot (plus or minus a couple of feet)
allIthis background noise, but would like to filter out as much of it as
can.theOne manufacturer of a similar "wind-up" antenna adds a capacitor to
wiregoingin order to lower the resonance frequency of the wire. If I were
tototry something similar (adding a capacitor, in series) in an attempt
bringranges,the resonance of the wire down into the 30 MHz range, what size (roughly)
ordoes anyone here have any suggestions?
TIA
Dave
[email protected]
RHF said:DAVE,
iane ~ RHF
the plug?
Thanks,
Dave
[email protected]
ofRHF said:DAVE,
Omni-Directional.
iane ~ RHF
TIA
Dave
[email protected]
= = = "Dave said:Argh. I just posted an empty message. Sorry. Please ignore.
Thanks for the info. I picked up a 300/75 ohm mini-plug adapter at the
store, but failed to get the second 75/300 ohm matching transformer to go
between it and the coax. Tomorrow.
Question: I have an odd situation, and can either install a 1/4 wave dipole
or a half-wave "random" wire loop (I think).
Right now the grounding rod is immediately below where the
dipole would go, and I think I could drop the 300 ohm twin-lead
down to it where I would ground one side (I think I have
this right, please correct me if I am wrong).
At that same point I would ground the shield of the coax,
and hook the other side of the dipole to the coax center conductor.
Coax would travel 10 feet or so to my window and the radio.
Other option involves moving the grounding rod
and doing something similar with the twin-lead as a long loop,
grounding one side of that and coax from the other side of the window.
Assuming these are workable ideas,
which do you think would work best? Again, [please don't hesitate to tell
me if I am full of crap. RF is new to me.
I really do appreciate your help. Like I said before, RF is totally new to
me.
Thanks,
Dave
[email protected]
