sharp photocopier SF 2022
Hi. I'm hoping that someone can tell me how to separate the 20 sheet
sorter which is wired to my Sharp SF 2022 photocopier so that the
copier will work without it. My problem is lack of space. The copier
is in excellent working order but takes up too much room. i have
disconnected the lead from the copier to the sorter but then the
copier won't work at all.
It would be much appreciated if someone can help sort this for me.
Thank you in advance.
Mark
JANA
Have you tried calling the Sharp service rep for your area? Most of these
units have some electronics that have to be sensed. They may have an
adaptor or a work around in their user menu.
JANA
_____
Mark
Andrew Tweddle
Mark
Try looking under the back cover where you remove the interconnect for
the sorter, there may be a loopback to tell the unit it has no sorter
attached.
Andrew
