David Farber
When this Sharp PG-M20S projector is powered up, the power led comes on,
then a few seconds later the lamp led starts blinking green. It blinks
slowly 11 times and then stays on. After a while longer, the led lamp blinks
11 times again. After a few cycles of this, both the led lamp and the power
led turn a steady red. Then, the internal fan powers down with the led lamps
remaining both red. You cannot power it back on until the power cord is
unplugged and plugged back in.
Continuity to the two pins of the lamp measure open but I'm fairly certain
that this is not how you test this lamp. Is there an easy way to test the
lamp without substituting it with another one? The replacement lamp for this
projector is over $400 and not returnable.
Thanks for your reply.
