Alasdair Campbell
I'm trying to research a fault a friend's TV has. A picture paints a
thousand words, so two shots follow this brief description.
Sharp 28JW-73H / 29JW73H (GA200 Chassis)
After the TV has been turned on for a few minutes a strong green and
yellow flicker appears on all inputs. I will have the opportunity to
preform a visual fault finding investigation in the next couple of days,
but in the meantime does this fault ring any bells with the engineers in
this forum?
The photo shows a bar, but in real-time, the bar is not visible, just a
stomach churning flicker at high freq. There is no vertical rolling
visible either.
I will be able to open up the TV in the next couple of days and check for
obvious faults, and am capable of replacing them, however if anyone
recognises the type of fault straight away I would be glad to glean some
of your wisdom.
best,
Alasdair
Photos:
http://www.alasdaircampbell.com/flicker.jpg
http://www.alasdaircampbell.com/flicker2.jpg
this forum?
visible either.
of your wisdom.
best,
Alasdair
Photos:
