Pat said:
Hi All;
I want to build a circuit that will take a voltage, and drive a geared
motor to a position based on the voltage. Position will be sensed by a pot.
What I cant figure out is the bidirectional drive. I have 12 volts, and I
also have 6 LM18200. Does anyone have a circuit that would work?
Pat
If you drive the whole thing from an AVR or a PIC then your problems are
solved. Not only can you select a device with an ADC and PWM output,
but you can put in the adjustable deadband, velocity limiting and
trapezoidal velocity profiling that you'll find you need to keep the
system stable and working correctly.
If you don't believe me then here's a handy circuit: When Vin > 0 the
4053 switches to the + input and the "DIR" output is on. When Vin < 0
the 4053 switches to the - input and the "DIR" output is off. When Vin
= 0 the DIR output oscillates like crazy and you get all sorts of weird
transients on "MAG" -- but what do you want for free? Figuring out how
to get some hysteresis in the comparator is your problem.
___
.---|___|----.
4053 | Opamp |
___ | |\ |
Vin /o-|___|--o---|-\ | Mag
o---o----o/ | >-----o--------o
| | o--------o---|+/
| | GND
| Comparator |
'--------------------|+\ | Dir
| >----o---------o
GND
created by Andy´s ASCII-Circuit v1.24.140803 Beta
www.tech-chat.de
