Hello. I've been working on modding my steel battalion controller and in the process learn about electronics so that i can help anyone else that is interested in my gaming community. If you don't know Steel Battalion is a giant robot game for the xbox that came out in 2002. I just finished putting in a rumble mod that works perfectly (thanks to Resqeliune) and i had a few other ideas on where i want to go with the project.
What i want to do is add a seven segment, or 14 segment led display so i can get a cool display of what gear i'm in. As much as for practicality and coolness sake. I found two that i might like to use but i don't know how or what driver or circuit to use.
7 segment:
http://www.westfloridacomponents.com/LED094PD/7+Segment+LED+Display+Red+Numeric+LTS-312AR.html
14 segment:
http://www.rapidonline.com/producti...in)+Starburst+display&moduleno=29389#techspec
Here's what the gear shifter looks like.
It's pretty simple, just seven points with a single ground that's completed by shifting the metal contact points in the gear shifter.
Here's the gear shifter.
What i want to do is interface seven wires to the seven different gears. And each gear will tell the driver (or whatever i may need to do it) to display R for reverse and so on. That way i can do away with a counter. How do i accomplish this?
7 segment:
14 segment:
