Series Parallel Problem
Since we can't see your circuit we can't tell.
A simple general solution is to find a pair of resistors either in series or parallel and replace then with a single resistance of the calculated combined value. Repeat this process until there is only one resistor left.
There are circuit topologies of resistors (I think the simplest has 5 resistors) where this process can't be used to completely solve it, but as I can't see your circuit...
That circuit can't be simplified using simple formulae for resistors in series and parallel.
You need to employ another type of circuit analysis.
What other methods do you know?
Kirchhoff, Superposition Theorem, Series/Parallel, Current Divider, Voltage Divider and System equations
Can you apply KVL and KCL to this circuit? Did you learn to use this to determine all voltages and currents in a circuit?
I tried to use a System of equations using the Kirchhoffs Laws but nothing
Try again. That is the way to do it. Find currents and voltages in the circuit, then use the current through the voltage source to find the equivalent resistance using Ohm's law.
Perhaps you can post the equations you derived and we can take a look at them. You may need to post any markup you've made on the original diagram if you have added any new non-obvious variables.
