REng said:
Hello All
We have an interesting problem - we are marketing a product (an
amplifier/signal processor) specific to our applications and we need to
prevent it from being opened up and reverse-engineered by direct
competitors.
I was wondering if anyone here knew of ways to laser off the marking
from the chips or fix/solder a flat metal sheet (like I have seen on
some boards) over the components. If the metal sheet is opened up, out
come the components as well.
R E
Sanding the numbers off the chips can deter someone unskilled in the art
from directly copying your device...UNSKILLED.
Potting the thing will slow them down a little more. But it will also
make it impossible to repair or upgrade the unit.
Once had a problem with a military product that had been conformal
coated. While the unpotting chemicals were indeed readily available,
there were significant OSHA restrictions requiring a major investment in
ventillation hoods and worker protection in order to use 'em.
For one skilled in the art, the problem is figuring out WHAT to do, not
HOW to do it. Given the external definition, it's often easier to
redesign it than to reverse engineer it.
If your design will change the world, get yourself a GOOD patent firm
and a BIG pile of money to defend it.
Put what you can inside a microcontroller or an ASIC or some such
device. Sand the labels off if you must.
Put your effort into sales. It's a lot more important to be first to
market with sufficient marketing to generate demand and sufficient
supply to meet it. A good idea started on a shoe string will invariably
be taken away from you no matter what you do to obfuscate the
implementation.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://
www.geocities.com/SiliconValley/Monitor/4710/
