Searching for Panasonic TK1-12V Relay Replacement
RosemontCrest
I am searching for a suitable replacement for a discontinued Panasonic
TK1-12V relay:
http://pewa.panasonic.com/assets/pcsd/catalog/tk-catalog.pdf
Single side stable with either standard PC board or self-clinching
terminals.
I'm not concerned too much about the coil parameters as I am the contact
specifications. Insulation/Isolation ratings should not be an issue in
this application.
After several hours of research, I haven't yet found anything with the
same footprint. I appreciate any suggestions.
Thank you,
Brian
Robert Baer
TK1-12V relay:
terminals.
this application.
Thank you,
Brian
What i have are some DPDT 12V relays: NEC MR62-12UKSRY (6 EA) and
AXICOM V2315-A5003-A201 (5 EA).
Would they do?
RosemontCrest
Would they do?
Thank you, Robert. I am looking for a quantity of 100-200 of a similar
relay with the same footprint. If all else fails, I may need to fab a
small adapter to accommodate a suitable replacement relay with a
different footprint, but I'd like to avoid that if possible.
TK1-12V relay:
Mouser still has 495 TK1-6V relays in stock, at $3.52 each in your
quantities.
http://www.mouser.com/ProductDetail...s/TK1-6V/?qs=sGAEpiMZZMuCv89HBVkAkx6OHdh/lc13
If you can hide a 240 ohm, 0.5 W resistor, or a couple of 120 ohm
resistors, or maybe even a 78L06 somewhere in the line to the coil,
maybe you can make the 6 V part work.
Matt Roberds
Spehro Pefhany
I see a couple thousand of the 2-coil type available OTS.
Best regards,
Spehro Pefhany
RosemontCrest
Thank you, Spehro. For this application, the relays are controlled by
software that is not easily changed, so they need to be single side
stable, not latching.
Maynard A. Philbrook Jr.
I did a little search and I found relays for SM that look's like you
could bend the pins straight.
Jamie
RosemontCrest
Thank you, Jamie. So, what will it cost me to coax a link from your fingers?
Brian
Don Lancaster
Brian
This one is a double pole but, you maybe able to snip the unused one.
you need to select the pin syle, there are three different types here.
http://www.mouser.com/ProductDetail/Omron-Electronics/G6K-2P-DC12/?
qs=sGAEpiMZZMs3UE%252bXNiFaVDkJvDEw2JZ1iEzJUvdS8k8%3d
Here is another possibility.
http://www.mouser.com/ProductDetail/Panasonic-Electric-Works/AGQ26012/?
qs=sGAEpiMZZMs3UE%252bXNiFaVNfu8HHr7g2JaqsOKtYkz8w%3d
http://www.mouser.com/ProductDetail/Panasonic-Electric-Works/AGQ20012/?
qs=sGAEpiMZZMs3UE%252bXNiFaVJz35TzGTaRdjYu8JGju0Ro%3d
With the panasonic line, I think the foot print for the coil and first
pole are the same as for the two poles, you maybe able to use those.
I can't remember the sight I went to that showed a SPDT smt.. I 'll
look more.
Robert Baer
Try Magnecraft 276XAXH-12D, or 49RE1C1VW-12DC-STO, or
49RE1C1VG-12DC-STO. Mouser has 624 of the first in stock and only a few
of the others in stock.
This is the only brand of 12V SPDT relays in Mouser stock that looks
similar (and has 2A or better rating); maybe DigiKey has others.
Beware: I used only the pictures for looks comparison.
That link does not work, no matter how one fiddles with it.
Try V23026D1022B201 as product number for DigiKey search (it is only
1A rating).
I can't help the reader from wrapping the lines but I just tried it, I
simply did a copy and past of the two lines and then deleted the ">>"
out of it and hit enter...
I think 1 amp contacts would most likely be fine for what he is doing.
