Tom said:
John,
Yes, I have provided the 12V from a battery (with short, twisted leads)
instead of from the DC/DC converter and the noise remains the same.
(if the 12V from the DC/DC is insufficiently filtered there is
additional noise in addition to this ever-present noise, but is caused
by the switching in the DC/DC converter, and is not white at all)
So I'm pretty sure it is the LM386 generating the noise. I can also
measure with the scope that the supplies are clean and the output has
significant noise, even if loaded with only 100 ohms instead of 10
ohms.
greetings,
Tom
What level is the output noise with a 10 ohm load ? Some figures would
be helpful.
Have you got the correct snubber network on the output - 47 nF and 10
ohm in series to ground ? Also correct power supply bypass ? These
things are critical to prevent the chip going into oscillation.
Have you also tried using the higher gain configuration - pins 1 and 8
open ?
Have you bypassed the unused input ?
Regards,
Adrian Jansen adrianjansen at internode dot on dot net
Design Engineer J & K Micro Systems
Microcomputer solutions for industrial control
Note reply address is invalid, convert address above to machine form.
