In my synth theres a program that reads the voltage in the battery and posts a value. I read about this type of circuit in high school, it just identifys a condition and then translates it into a value that that is posted by LED display or guage. This allows the equipment to warn the user that their battery is about to fail. When the battery fails and is replaced, the equipment is supposed to magically jump back to life and work...
The problem is that this equipment has a fail safe built into it that causes the little code to fail after you put a battery in it. This requires the owner to send the device back to the man and get him to reinstall the system the battery and what ever costing the owner multiple cases of tremons and a bundle of monies!
I did a lot of research on this thing. There are procedures that you have to follow when you perform the battery swap, or the system doesn't detect the new one. Now if you replace the battery without diconnecting any of the accesories...ie. the keys, the led panel, the mod pots, then the system doesn't know anything was done when you changed the battery, and it just reposts the OK values.
I did it once. It worked. But the board got hot and I didn't want to do it again. Besides all that high school BS could have been just that B*** S ***, but this last time, the main board failed(or the program isn't getting the right signal) of the new battery was made by someone who had the welder too high, or the power glitch problem happened... an all these cases, I am stuck with a "one shot Joe" synth that won't store my songs and programs anymore. Any body that can help me should, I'm sure there are a lot of problems like this out there, that should be hacked!
