ok before i begin i am very well aware of hazardous voltages and i use isolation transformers for all of my HV projects so please don't preach to me about the dangers of what i am asking. Having said that, my question;
i am considering a new project using an scr series regulator (not shunt) to obtain roughly 48 volts @ about 7 amps from a 110v main (via isolation transformer). my problem is i don't know enough about SCR control circuits or the way SCR's clip the wave form to know if it is feasible to regulate down that low. after the scr i intend to toss in a full wave bridge and filter capacitors to stabilize it. i have done similar things with triacs in the past by running 12 volt lamps directly from triacs connected to the wall outlet so i understand that those devices clip the wave giving me 110 peak and if done right about 12v average similar to a PWM.
i had tried doing a PWM supply with a rectified 170vdc (us mains) but the harmonics were giving me a major problem.causing all sorts of gremlins.
so the basic question is does anyone have any experience with the SCR controllers, can i successfully regulate 30-33 volts (rectified 42-46vdc) from the 110 mains
