SCR Motor Controller
Status
Not open for further replies.
You're right. Which made me realize it has to be something I did.
And it was. I forgot to attach the negative side of the capacitors to the negative bus. Stupid. :)
Minder, thank you so very much. You are the only reason I got this working!
Learned a lot about DIACs, TRIACs and some more about resistors and capacitors.... And a a good lesson was learned about paying attention and dilligence.
Sorry guys bumping up this post. I recently bought a device which is running similar circuit but is designed for 220VAC. I am thingking how I could modify it to run on 110VAC instead of plug it into step up transformer.
Here is the PCB look. The very left side(bottom red&yellow wire) goes to DC brushed MOTOR
It should run on 110VAC without a transformer but you may need to reduce the value of the rheostat to get up to full speed.
This idea, it is easier to build a Triac controller than a SCR style which requires the SCR's to be inside of a bridge.
M.
Can I use this circuit for a 90vdc motor. Let's say I need 10 amps max would I have to parallel triacs ?
Status
