W
Wes
Hi - I'm hoping someone can help me here. The basic problem is
that I have a circuit consisting of a bunch of #47 mini-lamps
that get turned on and off via a processor, and everything works
great EXCEPT that the lights get noticeably dimmer as more total
lights are on at the same time. The lights are controlled in
groups of 4, and each group of 4 that turns on has a relatively
dramatic effect on the brightness of all the bulbs that are
currently on. I would like the bulbs to stay close to their
designed brightness (relatively constant brightness regardless
of how many lights are on).
There are 16 lights total (4 groups of 4). Each group of 4 is
controlled by a shift register (595) output. The 595 output
drives a pair of MCR-106 SCR gates, and each SCR drives 2
bulbs. I have a 1K resistor connected between each 595 output
and the pair of SCR gates it drives.
For lamp power, I'm using a 12.6VCT 4A xformer. I've fed the
center tap and an outer lead to the AC inputs of a bridge
rectifier, so I get the 6.3VDC I need to drive the bulbs -
this works fine. The lamps are 6.3V / .15A, so with 4 amps
available I would think I should be able to drive 16 lamps OK.
I connected a sort of "status bulb" directly across the 6.3V
lamp power supply. I thought I would see it dim along with
the SCR-driven lights, but this one bulb stays relatively
nice and bright.
So, if just 1 group of 4 lights is on, they look nice and
bright. Calling that 100% brightness, when the next group
of 4 comes on, then all 8 lights drop to, oh, 85% bright.
Then when the 3rd group of 4 comes on, then all 12 lights
are about 70% bright. Finally, 16 lights on are all at
about 55% or so.
Anyone have any ideas as to how I can keep all of the lights
near 100% brightness? Thanks!! -Wes
nice and bright.
about 55% or so.
