SCADA software
bob watkinson
I've worked extensively with Protool but I've never seen Intouch, WINCC or
any other package. With my experience of Protool would I easilly be able to
adapt to these packages, indeed is there much difference?
Cheers Guys Bob
SQLit
Cheers Guys Bob
I have never used Protool. I have used Iconics, Intelliousion, and
WonderWare. Getting use to the key strokes is the hardest part for me.
JVL
Prolool is based on a TP or an OP. You always see a OP or TP on the
background, and you can link a function on a button.
WinCC is often based on a PC, and many and many more functions.
When you will make a prober program you need a lot of study.
Also you have to make a choise for a program langwitch S7 or PCS7. With PCS7
you heve a very powerfull system. Normaly for bigger machines.
Mincer
to adapt to these packages, indeed is there much difference?
Cheers Guys Bob
I have used Protool Pro & InTouch (wonderware) and I find both of
them pretty much the same and very limited.
Try some of the Biejer scada stuff. Very open, very scriptable & cheaper.
Mincer (on a dry run)
