Martin Brown
Don said:I would say more extreme than that by an order of magnitude, as in
more like 99.5% of visible spectrum content of low pressur sodium
being in one line pair having total bandwidtyh less than 1 nm, and the
next one down probably has less than .2% of the total.
We could probably agree to split the difference. In practice I guess it
is somewhere in between these two bounds. Either way it is close enough
to monochromatic by any reasonable definition.
I did a quick back of the envelope sum using NIST data and reckon there
are about 5 visible groups of lines in the sodium streetlamp spectrum
that are around 0.5% of peak each plus the red lines from the start gas.
The 2nd-place visible spectrum feature of a low pressure sodium lamp
is close to there, comprised of 4 lines: 567.0, 567.6, 568.2 and 568.8
nm. The first two of those are much stronger than the last two.
I saw that...
The Na entry has only one of the line pairs shown at all, the main one
in the orangish yellow.
He doesn't have enough horizontal resolution in wavelength to show the
gap, but I think both D lines are plotted adjacent with the 2:1 ratio
visible. It is still quite a fun educational page. A log/lin switch
would be nice.
This source cites 2nd place being .7%, which sounds a goog half an order
of magnitude high to me if it is a visible spectrum feature. (Likely
according to a spectrometer experiencing saturation or having uncorrected
non-flat spectral response or both.)
I dunno about that. With the sodium line saturated I get very visible
colour for the green line at ~567nm, weak colour for the blue doublets
and also some red lines from the initial cold strike gas.
We are in complete agreement on this point. Worst case using my
pessimistic estimate 95% pure and if you are right better than 99%.
Regards,
Martin Brown
