Samsung S7275 battery pins layout? To power with powersupply.
Hello all,
I am trying to figure out how to connect a linear powersupply onto my Samsung S7275R phone.
The battery of the type B105BE has 4 pins, as follows: A,B,C,D
A is unknows
B is minus connector battery
C is unknown
D is plus connector battery
What I did so far.
I connector a lab powersupply with a voltage of 3.8V onto the plus and minus of the phone. Then I power up the phone.
The phone boots, but shuts down.
I tried connecting a resistor between C and B with the values 10K,330 ohm, 2,2K, but the phone starts to boot, I see the samsung screen, then it powers down again.
There is no difference between both my attemps.
What Am I doing wrong? How is the battery thermistor connected to the pins? What value should I use?
( For my S6312 Samsung phone I successfully connected it to a powersupply, but the S6312 has only 3 pins.)
Help?!
KrisBlueNZ
Sadly passed away in 2015
I wouldn't assume that there are only passive components in there. Probably the best way to find out would be to take one apart.
