If you want something more automated, I would look up a comparator circuit. You'll have to do the research on part and voltage supply you have on hand. So, on one input is your voltage divider with you probe acting as one resistor to ground, and the other input could be tied to the center lead of a 10K pot. The output goes high when the + input goes above the - input. The output could be tied to a buzzer or LED depending on voltage. Like I said you'll need to do a little research.
