George R. Gonzalez
I know just enough about PC power supplies to be dangerous...
I'd like to run my PC in the back of my van, as efficiently as possible, so
using a 12V to 120VAC inverter is out.
My idea is, and please correct me if you see some major goof, is to do this:
(1) Snip out the MOSFET or transistor that is switching the rectified mains
voltage into the ferrite transformer.
(2) Install a hefty MOSFET to do the same switching, only from the 12V car
battery into the 5V secondary of the ferrite transformer.
(3) snip off the 120V wires on the transformer and hook them to the 120VAC
input wires (to power the voltage doubler, which powers the regulator chip).
The idea is to turn this circuit semi-inside-out, so we're using the 5v
winding as a primary and source for 5V, then the transformer works
backwardfs, powering the 12V and 120VAC lines.
The transformer should be running cooler, as it isnt loaded with the major
load (5V at many amps).
Sounds a bit crazy, but maybe has a chance of working?
