I really dont want to cause you a headache. I really try to understand.
Also how can we measure potential if we have no reference point ?
Are the rs422 circuits using lines A and B in turn as reference points to measure voltage between them ? Or maybe use the A line as ref point and measure pot difference to B line ? Thats the only case i can think of that will not need an extra common ground used from the "listener".
How is it possible ? there is no potential difference between the + of battery A and the + of battery B. Note that only the - sides of each batterys are tied to GND. and the resistor in that picture is not connected to it.Your circuit shows a resistor as a differential component between A and B lines. In that case any current flowing into the resistor via the A line comes out via the B line
I pictured the resistor to be the "receiver" or at least some oversimplified equivalent.ground connection is required as the receiver only evaluates the voltage drop across R. Current returns to gnd of the transmitter via the "batteries" shown. You have a closed circuit and that is fine.
