Greetings dear friends.
Today I was reading about RS422/485 protocols. I do know that these are differential line but that raise a question. Do they really need an extra signal ground wire or not ?
Ive seen it many times used without a ground wire, just the data + and data- lines.
How does the receiver get the information? Where does current flow to if there is no ground wire ?
I guess the line that is at 0V potential probably sinks current back also practically I have never seen rs422 systems use common ground. Is it because they share common ground through their power supplies? If that is the case then is it the way it is meant to be?
Not to mention that I have seen rs232 devices reading rs422 directly by interpeting 0V as -12 and +5V as +12V which i would NEVER do because this way you put the other data line directly to ground.
