No, there are two transistors bolted to the heat sink. That's why the heat
sink is there, to cool those two power transistors.
No, the spacing is consistent with a TO-220 transistor pair, and if it's
a linear pass regulator like it appears to be, there needs to be a big
transistor somewhere. Also, of course, there is the heatsink.
That IC is only control logic, it just takes some mystery input signal and
produces a variable voltage for the transistor base. Those two transistors
are doing all the hard work. BUT, if you want to replace the device with
a retrofit one, you need to know what that mysterious input signal is.
--scott
One key question in all this is if the interface from car to
"resistor block" is some kind of simple digital interface,
ie it sends some bits that get interpreted as "go to speed 3"
or does it send a PWM signal. My guess is the latter.
That's my understanding of what BMW does with the aux
radiator fan in the X5. Another German electronic miracle
that fails and in doing so, mysteriously drains the battery.
Someone should put an oscilloscope on this and find
out what the signal looks like. If it sends a digital code,
then making a replacement from scratch is a big
hurdle. If it's sending a PWM signal, they you could
build an equivalent from Radio Shack parts. It still
seems like more work than it's worth.
How fast are these things failing for those that want
to make their own? 2002 X5 here and it's only had this
problem once, about 2 years ago and replacement one
is still working. And another data point. The failure on
that X5 resulted in the blower draining the battery when
the car was off. Blower ran fine. Only odd thing in
retrospect was that when the car was off, a couple times
I heard a faint noise. In retrospect, it was probably
the blower getting just enough current to start to turn
then stop. And only noticed it a couple times. The
bad thing with the failure mode of this and the AC fan
is that both were draining the battery and both were
very hard to pinpoint, resulting in huge labor charges.
