terryc
Any recommendations?
terryc said:Any recommendations?
Sylvia Else said:Yes. Don't do it. It's a huge waste of money.
David L. Jones said:Not to someone who wants it.
I'm sure Terry is aware of the cost/payback implications. There are many
reasons why people get PV installations.
No different to anything else really.
Dave.
David said:Not to someone who wants it.
Dave.
Sylvia Else said:It doesn't just cost him money. It costs me money. He'll use the PV cells
to reduce his power demand when then sun is shining, and use grid supplied
electricity when it's not. This reduces the overall utilisation of the
grid and the generators attached to it, which pushes up the cost of the
electricity that it delivers. As a consumer of that electricity, I have to
pay more as a result.
David said:That's a very narrow minded view indeed.
Do you realise it may also help you?
You complained the other week that you needed a generator because of the
"parlous" state of the power system in Australia (and in Sydney where you
live). By Terry installing a solar system that might just help make the
power system less "parlous", and it might even SAVE you money by you not
having to buy that back up generator after all. You should be thanking him
for installing one.
Sylvia said:It doesn't just cost him money. It costs me money. He'll use the PV
cells to reduce his power demand when then sun is shining, and use grid
supplied electricity when it's not. This reduces the overall utilisation
of the grid and the generators attached to it, which pushes up the cost
of the electricity that it delivers. As a consumer of that electricity,
I have to pay more as a result.
Sylvia.
Sylvia said:I think it unlikely that his installation of PV cells would impact on my
decision to install a generator. I doubt I would ever be able to
determine whether he'd actually improved the reliability of my supply.
By contrast, the impact his installation has on electricity pricing is
quite direct.
Sylvia.
Davo said:It saves you money because in summer when loads are at their highest
running air conditioners, power is very expensive because peaking
generators are used, these are only used a few days a year and usually
run on very expensive diesel. Solar systems are ideal for reducing peak
loads in hot weather. Base load power generation is cheap, building and
running plant that might only be used a few days a year is extremely
expensive. Also, demand for power is highest during the day when solar
systems are most productive.
cth said:Your analysis of why the cost goes up to grid consumers is a pretty long
bow to draw.
If the grid is utilised less (on a reasonable scale), then one of two
things are likely:
1. There'll be surplus power and generally anything surplus gets cheaper or
2. Less fuel is consumed by the power stations reducing their running
costs, and thus a potential saving is there to be be passed on. Whether
the pass-on occurs or not, of course is debatable. More fool us to buy
from a rip-off supplier if they don't pass on savings.
There are many reasons why people get PV installations.
terryc said:Err, those monstrous power stations are spinning anyway 24x7. What I can
not work out is why I can not battery bank off peak electricty.
Second, even if 10K people did it, I doubt if they will have any effect
like the 10%, 20%, 305 electricty price hikes bouncing around.
terryc said:That is part of what I want to investigate further. Given that electricty
prices are taking off and a feeling that interest rates are going to stay
low for a while, this might be the best time to "invest"
Yep.
Trevor Wilson said:**Not IMO. The best time to invest will be later, when one of several
things occur:
* The cost of PV cells (amorphous) will plummet when supply comes remotely
close to meeting demand. Figure on a 90% reduction in PV cell costs within
20 years. Maybe as little as 10. It's hard to say, since as prices fall,
demand will rise.
* The 'feed-in' tarif in your location will play a part. In NSW, right
now, it's not a smart idea. In Germany, it is.
things
occur:
demand will rise.
* As mounting hardware becomes more standardised and more easily
available, costs will fall.
* As more guys become installers, competition will forces costs down.
All this needs to be balanced against rising electricity costs, of course.
MisterE said:There are a few niches where it works.
For example a 1kilowatt system can be had fully installed for less than
$4,000 after goverment rebates. With the 25 year warranty it should just
about break even at this point.
Also QLD you can sell back excess power for 44c/kwhour, about 3 times what
it costs to buy, so you will also save some on your power bill. I was about
to get one installed because it worked out marginally cheaper for me, but
they moved the $8,000 to families that earn under $100k.
