ROM contents of MC68HC11G5FN1?
James Meyer
The 68HC11G5 has 16K of ROM. Presumably, the ROM was hard coded at the
factory. I say that because it isn't EPROM or EEPROM, the package is
windowless, and I can find no information about programming it.
I'm also assuming that the suffix, FN1, would tell me what the ROM
contents are but I can find no information about that either. The chip is
obsolete, I guess.
The only thing I can think of that may be in the ROM is Motorola's
BUFFALO monitor. Can someone confirm or deny my suspicion?
Jim
bruce varley
obsolete, I guess.
Jim
I run my own OPSYS/dev environment for HC11, but once I had to interface
with a device incorporating BUFFALO. I added some brief notes on the topic,
which I can hardly understand myself now, to my reference docs. Here is a
snippet that you might be able to get something out of, sorry I can't make
it clearer. Jump to the addresses and see if anything comes back. IIRC, the
com settings are 96,8,n,1. Good luck
The Motorola BUFFALO opsys resides in ROM at 0E000H. Generally, devices
with BUFFALO also have EEPROM at 0B600H. The reset vector points to
the start of ROM, 0E000. The first 3 instructions in ROM are:
LDX #100AH
BRCLR 0,X 1 BUFEXEC ; If PE0 low, go to buffalo start
JMP 0F600H ; else go to EEPROM start
BUFEXEC: .............
James Meyer
LDX #100AH
The reason I asked is that all my development hardware is for the
"normal" 52 pin quad packages and the '11G5 comes in a larger 84 pin package.
It's got non-multiplexed address and data busses along with some other
enhancements.
I was trying to avoid getting a new system just for the bigger chip
unless it had something really neat inside. Otherwise I would have just plugged
it in and asked it what it was.
Jim
Trevor
obsolete, I guess.
FN1 in 'hc11s usually means the package type (PLCC)
temperature range 0-70C and the '1' means an E clock speed of 1MHz.
I don't know the contents of the ROM - the 'E' chips that I'm
familiar with have a 'B' suffix before the FN to indicate Buffalo.
HTH
Trev
Clifford Heath
contents
Normally those letters indicate the package type and max
clock rate.
Assuming you can control MODA and MODB pins, you can power up in
bootstrap mode. That allows you to boot-load a "talker" or ROM
dumper program into RAM, which can show you the entire contents
of your ROM.
I don't maintain it any more, but my DB11 'HC11 debugger has the
ability to do this, and to disassemble the code direct from ROM.
I never finished the Windows port, but it runs on several *nix's.
Google for it, or search polyplex.org/cjh.
Clifford Heath.
